Activity Forums DVD Authoring From Final Cut Pro to hardware DVD, which system?
  • From Final Cut Pro to hardware DVD, which system?
    Posted by Keicol on June 20, 2005 at 5:15 am
    I want to make DVD dailies from HD Masters (HDcam 23.98psf) digitized into Final Cut Pro Studio 5 using the Kona 2. DVD studio would take forever to make a DVD at this resolution, is there a hardware solution? I’m interested in the best look, least compression, 50 minutes of video per DVD. i’ve seen some hardware solutions (PCI Card) at NAB for about 6 thousand dollars but can’t remember who the company was…
    thanks, Keith
    Chris Borjis replied 21 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • Arky
    June 20, 2005 at 8:44 am
    Here’s one offering:
    w*w.optibase.com/Content.aspx?id=1681
    HTH
    John.
    (‘Arky’)
  • Keicol
    June 20, 2005 at 12:15 pm
    That was interesting, thanks, but it didn’t mention anything about taking from the Final Cut timeline to make the DVD, it seems I’d have to have a separate system and play back the timeline out through the Kona card and into the Optibase card on the other system, plus it seems that it would make HD DVDs, something unplayable on most DVD players, so I’m told….
    thanks, Keith
  • Chris Borjis
    June 20, 2005 at 4:09 pm
    can you playback the timeline in realtime from fcp?
    if so, a panasonic set top recorder could be the best
    option. Digital Dailies is something this box can do
    easily. http://www.panasonic.com
  • Keicol
    June 20, 2005 at 4:29 pm
    I’m not satisfied with the look with from that set top recorder, I was hoping for a more robust option. thanks, Keith
  • Eric Pautsch
    June 20, 2005 at 7:33 pm
    Are you looking to burn HD-DVDs? If so you can do that with DVDSP 4 but it will only play back on a G5. Hi Def DVD is still very much a thing of the future at this point – at least from a users stand point.
  • Roadkill
    June 20, 2005 at 9:32 pm
    [keicol] “I was hoping for a more robust option”
    This one is as robust as it gets: Pioneer PRV-LX1. 🙂
  • Chris Borjis
    June 20, 2005 at 9:46 pm
    have you tried the panasonic recorders?
    They are quite robust and industrial strength.
    Picture quality is among the best out there
    for realtime encoding on a set top.
    I have over 1,000 hrs on my laser diode
    and have not had one hickup. Some discs
    were 4hrs long.
    It doesn’t really get any more robust than that lol. 🙂
    For digital dailies this is ideal.
