Activity › Forums › Compression Techniques › From DVD-Video to FCP
  • From DVD-Video to FCP
    Posted by Brad Hebert on April 28, 2008 at 7:41 pm
    I’m trying to get uncopyrighted video from DVD to Final Cut. I’ve found some ways to do it, but they seem a little sloppy and I want to make sure I convert things the best way.
    I’ve used “MPEG Streamclip” with some success – but the audio always needs rendering in FCP. I was exporting as DV and resampling audio to 48k. It created files with “.dv” extensions – I’m not familiar with that. Should I export as Quicktime files?
    I’ve also tried dragging the VOB files onto the computer, then encoding with Compressor. I can’t get the audio to show up at all this way.
    Help?
    Brad Hebert replied 18 years, 5 months ago 2 Members · 2 Replies
  • Craig Seeman
    April 28, 2008 at 7:55 pm
    .dv is the DV data itself. It’s actually what iMovie uses for example. When capturing DV into Final Cut Pro over firewire, for example, the audio and video is split. Not so with .dv.
    Hope that isn’t to confusing explanation as to what’s happening.
    What you’d need to do in MPEGStreamclip is set it to DV NTSC (or DV PAL) MOV file. On Windows you’d set it to an AVI extension.
    In shot, set it to Export to Quicktime instead of DV. Set Compression to Apple DV/DVCPro NTSC. Set frame size to 720×480 DV-NTSC. You can set sound to Uncompressed Stereo Auto or you can change Auto to 48 kHz.
  • Brad Hebert
    April 29, 2008 at 12:51 am
    Thanks for clarifying all that. Everything works well now. Actually, when I select Apple DV-NTSC, Streamclip automatically chooses 720×480(something)frame, instead of 720x480DV-NTSC. I say (something) because I can’t remember exactly what it calls it right now. It seemed to work fine though. Is there a difference?
