Activity Forums Adobe Premiere Pro From DV interlaced video To progressive from cs4
  • From DV interlaced video To progressive from cs4
    Posted by Glen Perez on February 9, 2009 at 7:03 am
    hi, i have an edit wich is normal dv video (interlaced) but i want to export it as progressive from premiere cs4, i see an option in the media encoder that tells premiere to export as progressive… Wil it get really converted to progressive? thanks..
    Vince Becquiot replied 17 years, 7 months ago 2 Members · 3 Replies
  • Vince Becquiot
    February 9, 2009 at 5:17 pm
    Yes, but you will lose about half the resolution.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Glen Perez
    February 9, 2009 at 5:38 pm
    so how do i create full progressive frames from premiere?
  • Vince Becquiot
    February 9, 2009 at 6:04 pm
    You would have to shoot progressive.
    There are other solutions such as plugins or hardware processors to handle the process (expensive) but none will really give you the same resolution as your original footage.
    Exporting for the web is really the only reason you would want to de-interlace at this point, and your loss of resolution matters less.
    Both TV and projectors will display your footage correctly.
    Vince Becquiot
    Kaptis Studios
