Activity Forums Blackmagic Design From Decklink 10 bit SD to Decklink 10 bit 720P via AJA FS1
  • From Decklink 10 bit SD to Decklink 10 bit 720P via AJA FS1
    Posted by Andreas Wideroe on May 31, 2011 at 1:25 pm
    I need some help here.
    Is there a way to play back a 10 bit SD BM file on a PC with Mediaexpress, route the playback videosignal via SDI out into an AJA FS1 and out via SDI to another PC running Mediaexpress to capture a upconverted clip?
    I hope to avoid going to tape … The last part works well, but I’m not sure how to playback and send the videosignal out via SDI. Is this even possible with Mediaexpress?
    Cheers,
    Andreas
    Andreas Wideroe replied 15 years, 3 months ago 1 Member · 1 Reply
