Activity Forums DaVinci Resolve from davanci to 35 mm?
  • from davanci to 35 mm?
    Posted by Mohamed Sami on April 29, 2011 at 1:08 am
    after finishing color on davanci resolve exporting XML ok…
    what the process ” in details in the lab of printing ” to print it on 35 mm and what the best lab for printing and not expansive ????
    Bipin Varma replied 15 years ago 9 Members · 11 Replies
  • 11 Replies
  • Robert Houllahan
    April 29, 2011 at 1:58 am
    You need a display LUT which emulates the film recording process for the stock, recorder and lab you are using. Then make a set of DPX frames and a audio file. 35mm Film recording is necessarily expensive because of the film stock costs.
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
    http://www.cinelab.com
    MAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma.
  • Christopher Tay
    April 29, 2011 at 2:03 am
    How are you able to export XML from Resolve now ? There is no XML export in Resolve v7…it is a new feature in v8.
    Your question of lab printing is a loaded one and involves 3DLUT, calibration with the lab…etc. You also need to find out who is going to do the film recording. The film processing lab themselves or another post facility that owns a film recorder.
    Which is the best lab for printing and not expensive ? I don’t think anyone will be able to advise you here. You need to find out which are the film processing lab in your area and what kind of charges they will offer you.
    -chrispy
  • Illya Laney
    April 29, 2011 at 7:16 pm
    What area are you located in exactly?
    twitter.com/illyalaney
  • Mohamed Sami
    April 29, 2011 at 7:26 pm
    Egypt
  • Chris Regan
    May 2, 2011 at 12:35 am
    email dave.grove@efilm.com He is head of digital sales at Deluxe, Hollywood.
  • Stuart Blake jones
    May 2, 2011 at 11:21 am
    You could also try Digital Film Lab in Copenhagen, they have two Resolves, two Revivals, their own film lab and an Arri Laser.
    https://www.newdfl.com
    Best Regards,
    Blake
  • Illya Laney
    May 2, 2011 at 7:55 pm
    You should check out Fotokem/Raleigh Studios in Budapest if that isn’t too far of a trek for you.
    https://www.fotokem.com/index.php?option=com_content&task=view&id=91&Itemid=144
  • Chris Regan
    May 3, 2011 at 1:29 pm
    Yes, thank you. We have seen excellent negs from
  • Filip Orlandic
    May 5, 2011 at 11:14 pm
    Hello,
    we have Cinevator 5 real-time 2K film recorder with all options installed (direct-to-print with dolby sound, and also negative recording, …)
    We are also not that far away from you, around 1900km.
    (less than 3 hours airplane)
    contact me if interested on
    f.orlandic@gmail.com
    regards
  • Neil Sadwelkar
    May 6, 2011 at 8:56 am
    There are two CInevators in Mumbai, India. They churn out hundreds if not thousands of film prints every year. And the films there are really long – even three hours sometimes.
    They can give you a film print out from DPX exports out of your Resolve. You need to send them a sample of your DPX, preferably with a frame or two of Marcie and some wedges included. They can make a test output to match your DPX files.
    What’s important for them or whoever is printing your output to film, is what LUTs if any used whilst grading. It’s important that they see the picture exactly as it appears on your monitor. If that tallies, you can be assured that the print will match correctly.
    If you need a 35mm negative on intermediate stock (which is seriously expensive) then there are numerous, maybe two dozen or so Arrilaser recorders in various parts of India.
    If you’re interested, I can pass on their contact details to you and you can take it from there.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
