Activity Forums Adobe Premiere Pro From B&W to color
  • From B&W to color
    Posted by Anand on June 13, 2005 at 4:23 pm
    I have a very colorful footage and I wish that the clip starts in Black and White and seamlessly turn to color as it progresses. Since the B&W effect is not keyframable, I have used the Tint effect with its default settings, keyframed from 0 to 100, to do this. Although the effect is OK, kindly let me know if this is the right way or is there a better way to do it.
    S. Anand
    aka Andy
    Adobe Certified Expert, Photoshop CS
    David J replied 21 years, 3 months ago 3 Members · 2 Replies
  • Bart Conover
    June 13, 2005 at 4:29 pm
    Razor your clip in the timeline(the color version)at the point that you want the effect to start.
    Make the first clip(prior to the edit)B&W, no keyframing involved.
    Place dissolve at the edit point and adjust to you liking(duration).
  • David J
    June 13, 2005 at 7:39 pm
    The Color Balance (HLS) effect allows you to keyframe the saturation to manipulate color intensity using keyframes. Very easy to go to/from B&W in a single clip this way.
