Activity Forums Blackmagic Design From blackmagic to projector
  • From blackmagic to projector
    Posted by Jasmine1919 on November 6, 2006 at 5:55 pm
    hello,
    i want to use my projector as a third screen to my computer, specially for working with final cut. It would sufice if it double the image of my right flat screen actually, it is just for me to see the footage in big. For this I have bought a RGB phono to BNC cable which i have plugged into my projector , however I dont know which cable goes into which on the blackmagic side …. could you help me and tell whether what i am doing is actually possible?
    thank you so much
    Jasmine
    Kristian Lam replied 19 years, 10 months ago 2 Members · 3 Replies
  • Kristian Lam
    November 14, 2006 at 2:29 am
    Hi Jasmine,
    Which DeckLink card do you have?
    regards
    Kristian Lam
    Blackmagic Design
  • Jasmine1919
    November 15, 2006 at 3:59 pm
    hey, thanks for answering, i have the Decklink HD Extreme
  • Kristian Lam
    November 17, 2006 at 6:33 am
    I assume that your projector will have component video inputs. They usually look like 3 RCA type inputs that are green, red and blue. You need to connect the Y-out of the cable to the Green input, the B-Y output of the Blue connector and the R-Y output to the red connector. Since the DeckLink HD Extreme uses BNC connectors, you might have to get some BNC-RCA adapters.
    regards
    Kristian Lam
    Blackmagic Design
