Activity › Forums › Adobe After Effects › From Black & White to Color audio react
  • From Black & White to Color audio react
    Posted by Major Attila on December 19, 2015 at 8:58 pm
    Hello guys. I’d like to make my background react to audio so when the audio is lower then the background turns black & white but when audio is higher the background turns to its normal colors. Right now I am using the Black & White effects from colors and presets, the effect has opacity so I guess a simple expression would do the job. I tried using this expression :
    x=thisComp.layer(“Sound Keys”).effect(“Sound Keys”)(“Output 1”);
    linear(x, 0, 100, 0, 150)
    But this expression does it vice versa on how I’d like it.
    Major Attila replied 10 years, 9 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    December 20, 2015 at 10:35 am
    On a quick glance, reversing the last values to something like
    linear(x, 0, 100, 100, 0)
    should do it.
  • Major Attila
    December 20, 2015 at 12:05 pm
    Thanks. I had to do a little bit of tweaking but works fine !
