Activity Forums Apple Final Cut Pro Legacy from AE to FCP
  • Posted by Trace Burroughs on September 1, 2010 at 1:52 pm
    I know you can import an After Effects Project into Premier Pro using Dynamic Link or without, if I then save the Premier Pro project as an xml file can I then import it into Final Cut Pro, making it a FCP project.? Thanks
    Trace Burroughs
    LME COLLECTIONS
    lme-collections.com
    Dennis Radeke replied 16 years ago 3 Members · 2 Replies
  • John Fishback
    September 1, 2010 at 7:41 pm
    Let us know if it works.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Dennis Radeke
    September 2, 2010 at 12:15 pm
    No, that will not work. FCP does not understand what a .aep file is. You could render the After Effects comp, replace it’s usage in Premiere Pro and then export to FCP. That would be the only way I could think of it working.
