Activity › Forums › Adobe After Effects › from AE to FCP to tape
  • from AE to FCP to tape
    Posted by Dan Cooper on December 20, 2006 at 8:17 am
    Hey to those reading,
    The Problem:
    I have an 15sec animation that has been created in AE. It is for broadcast TV (PAL) and i need to get it onto a DV tape. My understanding is that this can’t be done directly from AE but from FCP however when i import the movie file into FCP it looses heaps of quality.
    How do I go about getting video from AE onto DV tape without loosing quality.
    The Solution:
    I’m totally open
    Dan
    Michiel replied 19 years, 9 months ago 4 Members · 3 Replies
  • Joshua Ferg
    December 20, 2006 at 1:42 pm
    I’ve never had this problem – export from AE as animation – drop into your FCP prject and export as uncompressed 8bit – PAL, if you’re using.
    Note – FCP can have issues laying off 8bit files to tape – if you have a RAID – drop the 8bit to the raid and have the sequence read the file from there. Sometimes FCP will drop frames if reading 8bit from local drives.
    Good luck.
    Josh
  • Steve Roberts
    December 20, 2006 at 3:33 pm
    Any material that needs to go onto DV tape has to be compressed to the DV codec:
    – mini DV tape: DV25 (the usual stuff)
    – DVCPRO tape: DV50 (DVCPRO50)
    – DVCPROHD tape: DV100 (DVCPROHD)
    All are variants of the DV codec, but at data rates of 25,50,100 Mbps respectively. I’m assuming you’re going to MiniDV.
    DV is a lossy codec. The quality loss from preview to compression is unavoidable, whether it happens when rendering in AE or FCP.
    Here’s what I’d do:
    1) make sure the comp has no saturated reds in it.
    2) render in AE to the DV codec.
    3) import the rendered file into FCP, and drag into a DV sequence so there’s no recompression.
    4) play out to DV.
  • Michiel
    December 22, 2006 at 1:03 pm
    or you could render out from AE as animation and then let FCP render to DV. This way you’ll always have a high quality, uncompressed master file to use if you ever need to compress it to a different format. (like mpeg 2 for dvd)
