Activity Forums Apple Final Cut Pro Legacy from 4:3 qt to 16:9 mpg
  • from 4:3 qt to 16:9 mpg
    Posted by Jason W. miltt on June 7, 2005 at 4:13 pm
    hi:
    i have finished a sequence of 4:3 material but i want to convert it to 16:9. not letterbox but real 16:9 with a dvd flag.
    what is the best way to do this?
    i imported into squeeze, added a 16:9 crop and then created an mpeg 16:9 but the results are strange.
    any ideas?
    thanks.
    Rainer Wirth replied 21 years, 2 months ago 2 Members · 3 Replies
  • Rainer Wirth
    June 7, 2005 at 4:17 pm
    You have to squeeze it in the 4:3. Make up a new sequence 16:9. Import the squeezed 4:3 sequence. Now you have a 16:9
    Rainer
  • Jason W. miltt
    June 9, 2005 at 3:26 am
    how to squeeze it?
  • Rainer Wirth
    June 10, 2005 at 2:47 pm
    You can put in a different ratio in the movement section of FCP and then largen the picture. You have to cut off a bit of the top and the bottom so the picture fits squeezed in a 4:3 window. You make a movement favorite in FCP and move it to the clips. All clips are the same. Now you have a 16:9 format. You loose sharpness and contrast.
    Rainer
