Activity › Forums › Apple Final Cut Pro Legacy › from 29.96 to 24fps
  • from 29.96 to 24fps
    Posted by David Carey on July 16, 2014 at 4:11 pm
    Hello
    I need to export a 24fps video file from a sequence that is 29.96. I’ve tried it and have problems with audio sync. Can anyone help me with this concern? I would truly appreciate and help.
    thank you
    David
    Shane Ross replied 12 years, 2 months ago 2 Members · 1 Reply
  • Shane Ross
    July 16, 2014 at 4:45 pm
    24fps STRAIGHT UP? Not 23.976? What’s this for?
    The best thing to do is export a full res, self contained QT file at 29.97…and then use Compressor to convert to 24 (23.98). Set the Frame Controls in the Inspector all the BEST. And this will take a while.
    Shane
    Little Frog Post
