Activity Forums Adobe After Effects Frischluft Lenscare depth-layer adjustment
  • Frischluft Lenscare depth-layer adjustment
    Posted by Xavi Xantos on February 3, 2010 at 1:02 am
    i’m using cinema 4d and lenscare in after effects for the dof.
    i am quite satisfied with the result, but i want to increase the area between sharp and blured but without rendering all depth maps again, so i try to apply some curves to the depth layer to increase contrast. though it shows no effect on the final image, even when the layer in solo view has more contrast now. when i switch to “depth-buffer” in lenscare there is no change viewable to the layer.
    so how do i get the layer tweaked to show the result in the final image. even in the manual it is mentioned that cures could be applied.
    best regards
    Yeison Rueda replied 16 years ago 4 Members · 4 Replies
  • Xavi Xantos
    February 3, 2010 at 7:07 pm
    yeah, worked, thanks!
  • Per Magne
    March 5, 2010 at 7:34 am
    Hi! I’m new to the Frischluft lenscare plugin in After Effects, and trying to discover how to make the depth buffer /z buffer. The only thing I’ve managed to find out is that you need the buffer, but not how to “make” it. Is it done in After Effects or do you need another software to do it? If any of you know of a good instruction on this topic I would love to get a link to it. I need to do some DOF in post for a movie were I’ve used a DOF converter on parts of the movie. Hope to hear from you.
    Best regards
    Per Magne Handegaard
  • Per Magne handegaard
    March 5, 2010 at 7:43 am
    Hi! I’m new to Frischluft Lenscare in After Effects. I wonder how you make the depth buffer / z buffer. Is it possible to do it directly in After Effects or do you need another software to do it? I need to do some DOF in post, because we have a mix of scenes taken with and without a DOF converter and I want to match them a little bit better than they are now. If any of you know of a good tutorial or instruction on depth buffer / frischluft lenscare I would be gratful to hear about it.
    Best regards
  • Yeison Rueda
    September 11, 2010 at 9:22 pm
    Hi, the Frischluft plugin uses information from ZDepth render pass done in most of 3D software, the plugin comes with two utilities, Depth of Field and Out of Focus
