Activity › Forums › Adobe After Effects › Fringing around white objects over greenscreen Primatte
  • Fringing around white objects over greenscreen Primatte
    Posted by Chris Smith on May 13, 2010 at 2:22 pm
    I’m using Primatte v4 on RED native (4K) footage. I’ve got people with white shirts in every shot, and I’m getting a dark fringe around wherever the white is composited over white. If I put it against a color, the fringing isn’t noticeable. Can’t use light wrap because they’ll be walking in front of each other.
    Matte choke, decrease opacity, fine tune seem to have no effect on this.
    Thanks in advance for any help on this!
    Todd Kopriva replied 16 years, 4 months ago 2 Members · 4 Replies
  • Chris Smith
    May 13, 2010 at 3:28 pm
    Basically the same thing, only greener. This sample is without any of the correction applied as well.
  • Chris Smith
    May 13, 2010 at 4:23 pm
    It was pretty well lit, yes. The footage is in a 16bit comp. I also tried 32 bit float.
    And thanks so much for your response to this!
  • Chris Smith
    May 13, 2010 at 5:08 pm
    Right, which is what I’ve been attempting for the last few hours.
    But it’s strange that I would have to fight the keyer like that. It’s almost as if it is adding pixels from the matte to the fringe area. So it’s only visible when compositing white foreground and white background.
    Thanks for your help. Maybe someone at Red Giant will have an idea or two as well.
  • Todd Kopriva
    May 16, 2010 at 1:49 am
    BTW, the Refine Matte effect in After Effects CS5 has some options for decontaminating edge colors—removing background colors from foreground objects at matte boundaries.
    This effect was created to help with Roto Brush, but we also split it out separately specifically to help with mattes like yours that are created through other means.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
