Activity › Forums › Apple Final Cut Pro Legacy › Fresh Install of Tiger and Final Cut Studio – Can’t capture DV!
  • Fresh Install of Tiger and Final Cut Studio – Can’t capture DV!
    Posted by Mitchji on June 24, 2005 at 6:22 pm
    I started with a new hard drive. Freshly installed Tiger and Final Cut Studio. Repaired permissions, updated to 10.4.1, ran Disk Warrior and repaired permssions again.
    Now I can’t capture NTSC DV using a Sony GV-D900 (the walkman DV deck). I normally use this instead of our DSR-11 for DV (as opposed to DVCAM) capture because sometimes the DSR-11 doesn’t play DV correctly.
    With Batch capture I get:
    “Batch Capture – preparing for capture”
    “Batch Capture – cueing source material”
    The footage is cued correctly then I get:
    “This operation could not be completed as there is no video” (I can see the video on the external monitor).
    I tried both firewire NTSC and Firewire Basic, same result.
    Then I tried capture now, same result.
    What next?
    Mitch
    Malcolm Thorpe replied 21 years, 3 months ago 3 Members · 3 Replies
