Activity › Forums › VEGAS Pro › Freezing suddenly occurs while rendering
  • Freezing suddenly occurs while rendering
    Posted by Jack Hawksley on July 19, 2015 at 1:36 pm
    So, for months, my computer has been fine rendering main concept .MP4 videos. But in the past couple of days, Vegas has been freezing at random times during renders with the following report:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 13.0 (Build 428) 64-bit
    Problem: Unmanaged Exception (0xc000001d)
    Fault Module: C:\Windows\system32\frapsv64.dll
    Fault Address: 0x000007FEE73B3D56
    Fault Offset: 0x0000000000003D56
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 13\vegas130.exe
    Process Version: Version 13.0 (Build 428) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2014-11-25 (Tue Nov 25) 20:33:08
    My guess is that the issue is linked to Fraps, but why start now? Everything has worked perfectly for a while, and I haven’t changed anything at all to cause this.
    Jack Hawksley replied 11 years, 1 month ago 4 Members · 4 Replies
  • Graham Bernard
    July 19, 2015 at 7:12 pm
    Deep in there is the reference to FRAPS as being the fault module. Do some research around this.
    Grazie
  • Steve Rhoden
    July 20, 2015 at 12:54 am
    Well, that’s FRAPS for you!
    That’s how it behaves. A non-friendly editing and unstable format.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Wayne Waag
    July 20, 2015 at 2:04 am
    I’ve used Fraps in the past without any problem, including fairly recently capturing some Google Earth footage. First, make sure that you have the latest version of their 64bit codec installed. If that’s not the problem, you could always transcode Fraps into a lossless codec that is Vegas friendly such as Lagarith, Magic YUV or UT Video. You can use the freeware Virtualdub to easily do this. Alternatively, you could try a different capture package such as Mirilli’s Action (I believe they have a 30 day trial period). I found that with my system, at least, there were fewer dropped frames with Action as opposed to Fraps and a lot more options for Desktop capture. Or lastly, you could try different editing software. Lots of options.
    wwaag
    Just a thought. Have you rendered other projects involving different source material? If not, you might give that a try. Although Fraps seems to be the likely culprit, it may be that the problem has nothing to do with Fraps at all. Worth a shot to try using same render settings but with different source material to see if you still have the problem or it disappears.
  • Jack Hawksley
    August 4, 2015 at 8:55 pm
    My apologies for taking so long to answer.
    Shortly after I posted my problem here it seemed to resolve itself. I will make sure my codec is up to date though, to avoid any future crashes. Thank you for your help! I will post back here if the issue returns and I’m still not able to resolve it.
