Activity Forums Maxon Cinema 4D Freezing points
  • Freezing points
    Posted by Jason Stirret on August 6, 2012 at 4:40 pm
    Is there a way, even possible, to freeze specific points within an object? I.e. can I say, freeze all the vertices located at 0-degrees along the X axis of an object. I would like to soft model some stuff, and of course I could go ahead and do it and then move the points via snapping or even individually, just painstaking at times. I would rather freeze the points to begin with.
    Jason Stirret replied 14 years ago 2 Members · 4 Replies
  • Brian Jones
    August 6, 2012 at 5:36 pm
    make a selection first and work within the selection or hide the points you want to freeze before you start
  • Jason Stirret
    August 6, 2012 at 5:43 pm
    Thanks Brian, just to clarify… If I hide certain points within an object then these points are not applicable to the soft movement of other points within that same object?
  • Brian Jones
    August 6, 2012 at 5:44 pm
    yes
  • Jason Stirret
    August 6, 2012 at 5:47 pm
    Life’s simple pleasures, thanks Brian!
