Activity › Forums › Adobe After Effects › Freezing motion blur in AFX?
Posted by Lance Copeland on December 12, 2008 at 8:34 pmHi I’m wondering if there is a way to freeze motion blur in after effects. Say for example, an atom. The nucleus would stay put in the middle, and the electrons are whizing around it in 3D space. I’d like to be able to freeze the animation, and move the camera to look at an individual electron and have it remain blurred. Sort of like the old bullet-time look where time stops and the camera moves around the space. I hope this makes sense.
Thank you very much,
Lance
For every vision there is an equal and opposite revision.
Lance Copeland replied 17 years, 9 months ago 5 Members · 6 Replies -
Jason Milligan
December 12, 2008 at 8:45 pmAs soon as the motion ceases, the built-in motion blur will disappear.
You could still keyframe a blur effect like “directional blur” or “compound blur” (or whichever is appropriate to your situation) so that as the inherent motion blur disappears, the blur effect increases. You could then orbit around that to your heart’s content. The real trick will lie in matching the original motion blur and timing the transition to a blur effect. -
Lance Copeland
December 12, 2008 at 8:51 pmCool idea…matching would be tricky but not impossible, especially if I go with a more stylized look, and cover up the transition from real blur to faked blur by a quickly moving camera. Thanks Jason! I’ll play around with that. It is a bummer that you can’t freeze the actual motion blur…Unless somebody knows some tricks for that. Meanwhile, I’ll give your idea a try.
Lance
Kevin Camp
December 13, 2008 at 12:09 amif you have your electron spinning in a precomp (or can precomp the electron layer), you could then create and adjustment layer at the top of the electron precomp and add the echo effect to fake the motion blur (you would want to disable motion blur).
you’d have to adjust the echo settings to create the blur you’re looking for, but i’d sstart with around -.001 for the timing offset, 20 or so fo the number and .9 for the decay. these setting will vary largely on how fast your electron is moving.
once you have the blur you’re looking for, you can go back to the atom comp and use time remapping to freeze time for the electron and it should freeze it with the ‘echo’ motion blur.
antoher way would be to generate the motion blur with a particle generator. attach your emitter to the electron layer, particles set to zero velocity and a size and decay (opacity) rate that seems like motion blur. and if you have particular, you could do this without precomping by manipulating the time factor settings (actually i can’t rmember if they are called time factor but they are at the bottom of the plugin’s settings). particular would also alow you to move a 3d camera around the electron and it’s tail of motion blur particles.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
David Bogie
December 13, 2008 at 4:28 pmVegas makes short work of electron pathways and atomic structure simulations. Vegas is a 2D layer which can be rotated in z-space. Vegas has built-in decay that appears like motion blur. You’d use two copies or two layers, one to get the electron particle and another to create the trail.
Vegas is remarkably cool and way underused. You just need art work that presents what Vegas calls a “contour.” A simple ellipse or circle will do. I use Illustrator layers.
Brian Maffit, from Total Training, created Vegas (and Shatter, WaveWorld, Colorama, Card Dance, many more) and had fabulous video tutorials on electron paths he used to create his Atomic Energy Effects Company logo. That stuff might be available online someplace.
bogiesan
Jon Geddes
December 15, 2008 at 7:51 amThis effect is also extremely easy to create with Trapcode Particular. I’m sure it could also be done with CC Particle World. Emit particles from a point, set velocity to zero, crank the birthrate up, adjust opacity over time so it fades out as trailing particles get further from the lead particle, and keyframe the particle emitter to move where you want it (or even parent the emitter location to a null object). I would definitely recommend using a particle system if its feasible for your project.
Jon Geddes
Motion Graphics Designer
http://www.precomposed.com -
Lance Copeland
December 15, 2008 at 7:51 pmThanks guys…It appears I have a lot of options. I will try them all and see what works best. I love creative cow, and appreciate all of you who have offered suggestions!
Thanks again,
Lance
