Activity › Forums › Apple Final Cut Pro Legacy › FREEZING FRAMES BUT AUDIO CONTINUES
  • FREEZING FRAMES BUT AUDIO CONTINUES
    Posted by Misfit on February 18, 2007 at 10:26 pm
    When I’m ready to transfer to video for some reason some of my clips freeze up but the audio continues. How do I correct this? I have Final Cut Pro 4
    Walter Biscardi replied 19 years, 7 months ago 3 Members · 2 Replies
  • Thaxter Clavemarlton
    February 19, 2007 at 1:00 pm
    There is a function in FCP that is often overlooked… and it can help with many audio and video “skipping”, “sticking” and “missing” problems.
    You should “Mixdown” the Audio for playback before you dub out of FCP, or during the edit, if you have audio/video stuttering, drop-outs, sync-slippage, or freezes.
    NOTE: Mixdown has even been demonstrated to help with slipping, skipping problems (or “missing” audio clips) for files being EXPORTED as QT (or similar) files out of FCP.
    First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:
    Sequence Menu > Render Only > Mixdown.
    You should see a dialog box telling you its rendering.
    It might seem to make little sense that “Mixing down” even simple audio tracks will “fix” complex video “freezes” or random audio dropouts to tape or export, but it CAN.
    NOTE: It does not matter of you only have one audio track, if there are random freezes during output, you should try the Mixdown.
  • Walter Biscardi
    February 19, 2007 at 1:09 pm
    [misfit] “When I’m ready to transfer to video for some reason some of my clips freeze up but the audio continues. How do I correct this? I have Final Cut Pro 4”
    No information about your system and media storage means we really can’t give you any good advice.
    Off the top of my head, get a faster media drive.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
