Activity Forums Adobe After Effects freezing for 5 seconds then continue
  • freezing for 5 seconds then continue
    Posted by Vincent Munoz on October 16, 2007 at 9:36 am
    i have a footage of a rollercoaster, i wanna na freeze it somewher for about 5 seconds then it should continue to play. how can i achieve that. please help me, i’m a newbie.
    vinzmunoz
    Kevin Camp replied 18 years, 9 months ago 2 Members · 2 Replies
  • Kevin Camp
    October 16, 2007 at 2:17 pm
    select the footage in the timeline. then choose, layer>time>time remapping… you will now see a time remapping property for the footage with two keyframes. position the play head at the point where you want the freeze and add a key frame. with that key frame selected, choose edit>copy.
    now would be a good time to extended the outpoint of the layer. pull the end (outpoint) of the layer bar to the right as far as needed. now select the freeze keyframe and the end key frame and position them where the freeze need to go back to realtime. go back to the point where the freeze would start again and choose edit>paste. it should now freeze between the two middle keyframes.
    if you need to make adjustments to the freeze duration, just select the two end keyframes and drag them.
    andrew kramer did a nice tutorial called time freeze, you can find it here.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Kevin Camp
    October 16, 2007 at 2:18 pm
    dave beat me… he has some mad typing skills.
    Kevin Camp
