Activity › Forums › Adobe After Effects › Freeze time with trapcode particular
Posted by Daniel Weaver on February 16, 2010 at 7:47 pmOk so I want to use particular to have particles that do not move, but stay fixed in 3D space to rotate around. You would assume it would be by stopping particle births, but then obviously there are no particles at all!
Steve Bentley replied 8 years, 1 month ago 4 Members · 4 Replies -
Michael Szalapski
February 16, 2010 at 7:57 pmI would not assume it would have anything to do with particle birth. If you stop people from giving birth, it wouldn’t stop time on our planet.
Try under the physics twirly and going to Physics time factor. If you go to the spot you want the particles to freeze and keyframe it from 0 to 1, you should be happy.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Austin Hill
August 1, 2018 at 10:16 pmThis is MOSTLY the correct answer, however, you need to keyframe from 1 to 0.
Michael Szalapski
August 2, 2018 at 12:24 amSorry, yes! 1 to 0!
– The Great Szalam
(The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Steve Bentley
August 2, 2018 at 1:24 amOr if you want to have particles emitted from an object and don’t go anywhere just make their velocity zero (and any randomness 0 as well) and after the first frame keyframe the birth rate to 0. They will be frozen in the spot they were born.
