Freeze frames suddenly fail in project
10.0.6
About 30 minutes into an edit, adding a freeze frame results in a blank clip that has what looks like a primary & connected clip graphic. No video. Name of the clip is correct, that is, the clip that should be frozen there. But nothing.
Earlier freezes in the project are OK. FF seems to start failing randomly around the 22:00 mark.
I can go earlier & create FF’s no problem.
UPDATE: entering Retiming & selecting a Hold does work.
Ideas?
