Activity › Forums › Apple Final Cut Pro Legacy › Freeze Frames
  • Posted by Tad Newberry on June 6, 2006 at 7:36 am
    i’ve got a clip where i made a freezeframe in the middle of the action for three seconds, then it continues on in realtime. when i scrub through this section on the timeline, i get a perfect, single-field freeze frame (no “jiggling”). when i play it or render it, i get the two-fields bouncing around. i think i’ve checked all my presets and preferences, but see no place that seems to affect this. any quick ideas?
    thanks for helping out a bonehead!
    Tad Newberry replied 20 years, 3 months ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    June 6, 2006 at 12:19 pm
    You should not attempt a serious edit by only looking at the computer monitor for judging quality.
    FCP is designed as an editing SYSTEM to be operated with an external video monitor connected
    (through a camcorder is just fine) DURING the edit process.
    The external video monitor would have shown you that many video “freeze frames” will wiggle, dance, jitter, flicker, etc.
    This Still-frame “flicker” is absolutely normal and is due to the fact that video “frames” are actually made up of TWO “fields”.
    If there is a lot of ACTION (or motion) in the frame you chose to “freeze”, the 2 fields will appear slightly different from one another and will jump back-and-forth between themselves, over and over during the “freeze”.
    To solve the problem, just add the “Flicker Filter” or, better still, the “De-Interlace Filter” to the freeze(s).
    Effects (tab) >
    Video Filters >
    Video >
    De-Interlace (or)
    Flicker Filter
    Again, if you watch the external monitor, you will see the flicker go away after a filter is applied.
  • Tad Newberry
    June 6, 2006 at 5:10 pm
    ya, i realize about the output/broadcast monitor, and what is odd is that NONE of the filter affects are showing up on my monitor (though they did a few days ago)! yikes. somewhere i changed a setting so that my output monitor is only acting like a second computer monitor (which i don’t want). very odd…i’ve asked Blackmagic about this as well since i can’t figure out what i changed that made it this way…
    my guess is that when this is figured out the flicker on the freeze frame will be gone as well? : )
