Activity Forums Media 100 Freeze frames
  • Freeze frames
    Posted by Kieran Matthew on March 26, 2008 at 7:05 pm
    Hi Folks,
    OK, my brain is fried at the moment, so it might be me, but is there something up with freeze frames in V12?
    Normally if I wanted to make a freeze frame of the end of piece of video I’d double click the video, jump the CTI to the end, hit freeze frame and render, and away we go.
    Now though when you hit freeze the CTI jumps back into the clip, forcing you to move it again. Also the duration, regardless of what it is set to, assumes the length of the original clip no matter how short.
    Now is this a bug, or am I missing something really simple!
    K
    Andrew Mehta replied 18 years, 5 months ago 3 Members · 5 Replies
  • Floh Peters
    March 26, 2008 at 10:36 pm
    We use it a little bit differently, and this still seems to work:
    Double-click your clip on the timeline, move the CTI to the end.
    Expand Edit suite, Click on “freeze” and the field you want to use.
    Collapse the Edit suite again, and drag the clip from the Edit suite clip window to your timeline.
    Not really sure if there have been changes lately to the freeze frame action, but the way we do it all the time still works.
  • Kieran Matthew
    March 26, 2008 at 11:45 pm
    Hi Floh,
    The CTI still jumps back on my system with that method, though that’s no biggie. Your way cures the duration issue, so for that I’m greatful.
    Thanks again
    K
  • Andrew Mehta
    March 27, 2008 at 7:15 pm
    Am still on 7.5 in OS9, but I never usually bother with moving a CTI. I just cut a clip where I want a still, double click on it, click “Freeze” in the edit suite window, entering a desired clip length if I don’t like the default 10seconds, and apply, and then it sits in my bin ready to use.
    ^_^
    Isn’t version 7.5 lovey?
    <3
    Heehee...^_^
  • Floh Peters
    March 27, 2008 at 7:20 pm
    [Andrew Mehta] “Isn’t version 7.5 lovey?
    It definitely is, but seriously, I would not want to change with you 🙂
  • Andrew Mehta
    March 27, 2008 at 7:25 pm
    =P Tsk.
    And there was me, going to ask for a swap. ^_^
