Activity Forums Blackmagic Design Freeze Frame with alphas Problem.
  • Freeze Frame with alphas Problem.
    Posted by Neil Sinclair on January 16, 2007 at 12:55 pm
    I’ve posted this on the AJA Forum with no solution and I’m wondering if you BM folks can shed some light.
    I’m using two systems, one with a BlackMagic extreme and another with Kona LHe.
    On the AJA system, when performing a freeze frame on a graphic (created in AE 7.0) that has alpha attached, the opacity of the alpha
    changes when frozen. There is a 3-5% shift in luminance between the original graphic and the freeze frame of the graphic.
    I assumed this to be a AE related setting but I get no such problem whilst doing the same edit, with the same file
    on the Decklink system. Any ideas why the difference?
    Neil Sinclair replied 19 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
