Activity Forums Apple Final Cut Pro Freeze Frame saved in browser
  • Freeze Frame saved in browser
    Posted by Eli Hollander on January 27, 2015 at 2:15 am
    I think I know the answer (no), but can one create a freeze in the browser that stays in the browser as a still frame clip? I know I can create a connected freeze frame that is placed in a project, but that doesn’t do me any good, as I want to use these “stills” in my project as source clips.
    I also know that I can export “current frame” as a TIFF or PNG and then re-import it, but is that the only way to get a selected frame into the browser?… it seems a bit clumsy or cumbersome.
    Any suggestions, please.
    Eli
    Eli Hollander replied 11 years, 7 months ago 2 Members · 4 Replies
  • Nick Toth
    January 27, 2015 at 2:53 pm
    Make the freeze frame a compound clip. That will put it in the browser.
    anickt
  • Eli Hollander
    January 27, 2015 at 11:01 pm
    Yes, I had thought of compound clips, but I was staying away from them… I think I am still operating under the old prejudice against compound clips, especially if I have many dozens of them. But I guess that has changed and compound clips are not to be shunned any more.
    In any case, compound clips is definitely a good way to do what I need. Thanks for your suggestion, Nick.
  • Nick Toth
    January 28, 2015 at 8:39 pm
    No problem. When you drop them into your project you can break apart the compound clip Shift Command G if you’re concerned about getting too many compounds in your project.
    anickt
  • Eli Hollander
    January 28, 2015 at 11:05 pm
    Brilliantly good point about getting rid of the compound, and it’s great how unlikely things can be used as stepping stones… Now, if we just had scripting, it could be done with one keystroke.
    E.
