Activity Forums VEGAS Pro Freeze-Frame Question
  • Freeze-Frame Question
    Posted by Dale Spetz on October 24, 2007 at 8:39 pm
    When I want to “freeze-frame” in Vegas7, I have to enlarge the track height in order to precisely control the “velocity” to “0”. With my typical track height, I can only control the velocity setting to “something close” to zero.
    Is there an easier way to freeze-frame where I can just manually enter the value of zero for velocity?
    I do this often and my current process is pretty cumbersome.
    Dale Spetz replied 18 years, 11 months ago 2 Members · 2 Replies
  • Edward Troxel
    October 24, 2007 at 9:17 pm
    Right-click the velocity point, choose “Set To…” and type in 0.
    Edward Troxel
    JETDV Scripts
  • Dale Spetz
    October 24, 2007 at 9:27 pm
    Thank you, Edward. I see that now. Previously, I had been splitting off the last frame, then manually pulling the velocity bar down to zero.
    Your method is much better. No splitting. Just set two points–second one to zero. I hadn’t realized that the “points” had the option of entering the numberic value of zero.
