Activity Forums Apple Final Cut Pro Legacy Freeze Frame Hue Change on export
  • Freeze Frame Hue Change on export
    Posted by Derek Tow on February 29, 2012 at 6:18 pm
    Hey…
    I have a clip that I have added a freeze frame to the end of and dissolved it out. Very standard fare. In the timeline, there is no issue as I scrub through the transition to freeze. But in the exported QT file, the hue of freeze frame lightens slightly and changes hue becoming a bit green and noticeably so.
    Specs – FCP 6.0, MacPro 8 core
    Timeline is ProRes 422 1920×1080.
    Exporting QT file using same settings as in sequence.
    Any thoughts?
    Derek
    Derek Tow replied 14 years, 6 months ago 3 Members · 4 Replies
  • Matt Lyon
    February 29, 2012 at 7:45 pm
    Hi Derek, I’ve noticed this too and have found two workarounds:
    when you export check the “recompress all frames” option
    or
    instead of using a freeze frame, razor blade the very last frame and copy-paste it as many times as you need. Then use a slug on the track above, with a fade up, to accomplish the dissolve.
    hth,
    Matt Lyon
    Editor
    Toronto
  • Edward Brosens
    February 29, 2012 at 9:00 pm
    Hey Derek,
    I think I know what you mean and it might be happening due to a difference in gamma settings.
    What happens if you set the video processing settings like this (sequence settings)?
  • Derek Tow
    February 29, 2012 at 10:22 pm
    Great ideas. I’ll try these tomorrow. Stay tuned…
  • Derek Tow
    March 1, 2012 at 3:38 pm
    Thanks Matt – the recompress all frame setting fixed it.
