Activity Forums Avid Media Composer Freeze Frame greyed out in drop down.
  • Freeze Frame greyed out in drop down.
    Posted by Cammie Noel on March 20, 2012 at 10:13 pm
    Have made progress, have MC tutorial book ect. Have followed instructions for doing a freeze frame but when i reach the clips pull down menu after following steps(mark in / match frame,) then the function for freeze frame is greyed out. Again any help is much appreciated.Cheers
    Steve Knattress replied 14 years, 5 months ago 3 Members · 2 Replies
  • Scott Cole
    March 20, 2012 at 10:24 pm
    Typically Freezeframes can only be made of clips, not from a sequence. Match to your clips and then try the freezeframe. If you need to make a freezeframe of an effect in a sequence, do a mixdown and then load that mixdown into the source monitor, park on the needed frame and create your freezeframe.
    M. Scott Cole
    Senior Post Production Editor
    60 MINUTES
    CBS News, NYC
    sc6@cbsnews.com
    mscottc@comcast.net
  • Steve Knattress
    March 23, 2012 at 12:57 pm
    After match framing you are selecting the source window before going to the clip pull down window?
    Note here, you can also select the type of freeze if you have interlaced material.
    You can also add a zero speed time warp effect, at a given point.
    This is good if you are trying freezes at different places on your clip.
