Activity Forums Avid Media Composer Freeze frame Avid MC6 question
  • Freeze frame Avid MC6 question
    Posted by Sheree Day on November 9, 2016 at 6:51 am
    Just wondering if it’s possible to grab a freeze frame from the Record monitor in AVID MC6?
    Why you ask?
    After laying out everything on the timeline I add a watermark in the lower thirds left side, and I need an image of one shot within the sequence to make a jpeg (or any image format not just jpeg – it can be TIFF etc).
    When I put the playhead over the timeline and click on the record monitor and go to clip / freeze frame, the freeze frame is grey so I can’t use it.
    I did put the image full screen and do a screen shot, but I was wondering if it’s possible to do it within Avid?
    Thanks in advance for assistance.
    Sheree Day replied 9 years, 10 months ago 3 Members · 3 Replies
  • Ricky Barrow
    November 9, 2016 at 12:38 pm
    You can “Export” a graphic file – many choices: JPEG, PNG etc.
    Ricky
  • Glenn Sakatch
    November 9, 2016 at 2:38 pm
    Here is how i’ve done it for years…bit of a PITA, but in reality, it takes about 5 to 10 seconds total.
    mark an in/out point on your timeline to get a duration of 1 frame at the point you want to freeze.
    Then create a video mixdown of that section (because its only 1 frame it takes up hardly any space, and is instantaneous)
    load that video mixdown in the source viewer
    create a freeze frame of that
    Glenn
  • Sheree Day
    November 10, 2016 at 6:17 am
    Thanks Glenn that was brilliant – I tried and it worked perfectly
