Activity Forums Apple Final Cut Pro Legacy Freeze Frame
  • Posted by Tonycity on November 1, 2005 at 9:07 pm
    Ok, this is like rocket sience. What is the methood of creating a freeze frame in the middle of a moving video at exactly the moment you want it to.
    Using, finalCut Pro
    Espnetboy3 replied 20 years, 10 months ago 4 Members · 3 Replies
  • Rob Forsythe
    November 1, 2005 at 10:12 pm
    PLAY-FREEZE-PLAY
    1. In the Canvas (timeline), put the cursor on the exact frame you wish to FREEZE.
    2. Hit the ” f ” key. This puts this frame (and its entire clip) into the Viewer.
    3. Hit “shift-N”. This creates a new “clip” that consists of ONLY the single (frozen) frame in the Viewer.
    4. In the Viewer, mark an IN and OUT for the number of seconds and/or frames (duration) you wish the FREEZE to last.
    5. On the timeline, INSERT the FREEZE (drag it over to the Yellow Box in the canvas or hit F9) into the timeline.
    6. Render. The timeline will play moving video up to the insert point, then FREEZE for the duration you marked, and then start playing (moving) again right from that point.
  • Eli Mavros
    November 1, 2005 at 11:30 pm
    you might want to also put the de-interlace filter on the freeze frame or it might appear to jump around.
    -eli
    Eli Mavros
  • Espnetboy3
    November 2, 2005 at 5:18 am
    Or you can put your cursor on the point you want and go to modify make freeze frame
    Whaaala
