Activity Forums Maxon Cinema 4D Freeze Displacement
  • Freeze Displacement
    Posted by Ryan Fannon on March 18, 2010 at 3:41 pm
    Is there a way to freeze the displacement during animation? I have displacement on in a texture. Whenever I animate the object the displacement animates too. Is there a way to freeze it in C4D 11. I searched the forums and found a topic similar to this from 2002. They recommended using a plug-in. I checked the link they posted, but it no longer works. I was hoping that MAXON would have enabled an option.
    Adam Trachtenberg replied 16 years, 5 months ago 4 Members · 4 Replies
  • Randy Johnson
    March 18, 2010 at 3:58 pm
    What are you using for displacement? If it is noise you need to to turn all movement to 0.
    /Randy
  • Brian Jones
    March 18, 2010 at 5:48 pm
    …or you might need a Stick Texture Tag
  • Ryan Fannon
    March 18, 2010 at 5:55 pm
    I have the movement down to zero, but it is still moving when it is animated. Not sure why. It may be because I set keyframes on the displacement amount before I turned the movement down to zero. I also have a stick texture tag on the geometry.
  • Adam Trachtenberg
    March 18, 2010 at 7:37 pm
    Can you describe how it’s moving?
    Otherwise … if you have MoGraph you can use the displacement deformer to bake the displacement into your object:
    * make object child of displace deformer;
    * set deformer to emulation mode;
    * place deformer in a HN object with sufficient render subdivisions to produce the effect you want;
    * make the HN editable or do current state to object.
    Of course this way you’ll wind up with a very high-poly object in your scene and lose the RAM-saving advantage of sub-poly displacement….
