Activity Forums Adobe After Effects Freeze Comp and play animation in it while freezed
  • Freeze Comp and play animation in it while freezed
    Posted by Walter Stichelt on December 30, 2016 at 10:13 am
    Hello everyone, i hope you survived Christmas well.
    Is there any possibility to play a video/animation in an freezer comp?
    I have a 3d Animation and need to stop it for some seconds to play a video on a solid with 3 informations.
    How can i freeze the Animation and play the video inside?
    Chris Brett replied 9 years, 8 months ago 2 Members · 3 Replies
  • Chris Brett
    December 30, 2016 at 10:36 am
    Hi Walter
    — if I understand correctly I think you can do this by duplicating the layer – freeze the bottom layer – then mask the top layer so that it shows desired area only
    —————————– chris —
  • Walter Stichelt
    December 30, 2016 at 12:42 pm
    Hm no that won’t work in that case.
    I have a rendered 3D animation, 3D solids and a 3d Camera.
    What i try to do now is, i still use time remapping on the main animation, duplicate the keyframes wit the 3D data onto an new comp and just move the keyframes and create that break that i need.
    That seems to be the easiest way right now.
  • Chris Brett
    December 30, 2016 at 12:53 pm
    ….. I see — theres also …..
    1 – duplicate comp
    2 – hide ( or delete ) elements you want to keep moving in bottom comp and freeze bottom comp
    3 – hide ( or delete ) elements you want to freeze in top layer
    ——————— think this should do it ( ? ) — but if not sounds like you have it covered anyway ?
    ———————————- all the best —–chris —
