Freeze baked soft body dynamics mid-animation.
What I want to achieve is super simple, really dumb if it’s not a stock feature… Maybe there’s a plugin that will allow me to achieve what I’m after?
Using R20 — I created this noodle dropping animation with help from a tutorial by CGShortcuts. The noodles fall using soft body dynamics, and eventually settle in the bowl (as show in screenshots). I baked the dynamics in the project settings, and after much trial and error, got them to fall the way I like without exploding noodles everywhere….
The problem is that they vibrate a lot (typical dynamics) and don’t really ever stop, so I want them to freeze in their settled position completely. (Make into a still object)After that they need to be able to be moved (not dynamically), because I am going to be putting this whole animation on a conveyor belt for a infinite loop.
Duplicating the layer stack resets dynamics, and of course noodles wont fall the same way twice.
I’ve seen solutions like “don’t bake, just delete the dynamics on the frame that you like” — Not possible because I need to keep the animation prior to the still frame, also that makes the noodles disappear completely.
Any solutions, resources would be helpful. Thanks!
