Activity Forums Adobe After Effects Expressions Freez time with marks
  • Freez time with marks
    Posted by Marcelo Cabral on March 13, 2013 at 3:57 pm
    Hi, I am working in a project which has severals animation. I nee to stop one of the animations using marks in other layer called “control marks”. I want to show the intro before the indicator pass over the “in” mark and I want to keep paying the animation after the indicator pass over the “out” mark. Is this posible? thanks in advance.
    Marcelo Cabral replied 13 years, 6 months ago 3 Members · 3 Replies
  • Todd Kopriva
    March 13, 2013 at 8:25 pm
    There’s an example here that shows how you can use markers to trigger animations.
    Beneath that example is an example about starting and stopping animations at specific times. Between those two examples, you should be able to figure out how to stop and start an animation at markers.
    After Effects team blog
  • Dan Ebberts
    March 13, 2013 at 9:34 pm
    See if this is close to what you’re after:
    m = thisComp.layer("control marks").marker;
    if (m.numKeys > 1){
    if (time < m.key(1).time)
    time
    else if (time < m.key(2).time)
    m.key(1).time
    else
    m.key(1).time + (time - m.key(2).time);
    }else
    value
    Dan
  • Marcelo Cabral
    March 13, 2013 at 9:44 pm
    Dan this works amazing!! thank you for all your support.
