Activity Forums Adobe Premiere Pro Free tutorials for Twixtor available
  • Free tutorials for Twixtor available
    Posted by Peter Litwinowicz on May 16, 2005 at 6:48 pm
    Hey all,
    Slow motion, speed up and variable speed (time remapping) software that uses motion estimation can be a very difficult topic to get your head wrapped around. Due to overwhelming demand, we have developed tutorials that explain the concepts of retiming and motion estimation with respect to Twixtor.
    And the good new is: THESE TUTORIALS ARE FREE.
    Twixtor Basics
    Tutorials for After Effects, Final Cut Pro, Premiere Pro and combustion.
    These tutorials explain the basics of Twixtor and why you’d want to use motion estimation in order to time “warp” your clips. Also explained are concepts that will help you figure out how to set up Twixtor and which settings to tweak in order to get the best results. Included in the basics tutorials are sample projects, sample clips and explanations tailored for each for each of the four applications.
    You can download the tutorials from here: https://www.revisionfx.com/rstwixtortutorials.htm
    Note that we still have our sample projects available for the more advanced features found in Twixtor Pro.
    Be forewarned, the tutorial package is huge (217Mb). Please note that we do not have the resources to mail physical copies of the tutorials to you.
    Pete Litwinowicz
    Peter Corbett replied 21 years, 4 months ago 4 Members · 5 Replies
  • Craig Howard
    May 16, 2005 at 9:23 pm
    Any chance of the tutorials getting broken up to more manageable file sizes Pete ?
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Peter Corbett
    May 17, 2005 at 5:51 am
    Speaking of Twixtor, does anyone else find it’s stability a bit flaky with Premiere? I’ve had to switch to Boris Continuum (Optical Flkow filter for slo-mo) because of the constant crashing with Twixtor 4.5.
    Peter Corbett
    Powerhouse Productions
    Australia
  • Shin Kurokawa
    May 17, 2005 at 8:48 pm
    ” Speaking of Twixtor, does anyone else find it’s stability a bit flaky with Premiere? ”
    Have you tried “Plenty of Memory” unchecked? (i.e. OFF).
    Also, I’ve seen it freeze up if I define the color
    source / secondary source in T4.5, then move tracks
    around, but it doesn’t happen all the time.
    ” Any chance of the tutorials getting broken up to more manageable file sizes Pete ?”
    As for *these* tutorials, the main reason why
    they’re big is that they have a lot of footage
    (incl. full-NTSC/PAL sized clips,
    even though they’re very compressed and shared
    by the html guide as well as the project
    files for various host apps). They also have
    a lot of illustrations as opposed to formulas
    and such, to add some Physics-For-Poets feel.:)
    These were originally done for the recent
    NAB swag CD.
    Also, not a step-by-step tutorial, but smaller
    sample projects are available at
    All the way at the bottom of that page.
    -Shin
  • Peter Litwinowicz
    May 20, 2005 at 3:42 pm
    We’ve had no one report problems with Premiere, but that just might mean that no one is reporting the problem. Can you give some specific setups or things that you do when Twixtor crashes for you?
    Pete
  • Peter Corbett
    May 20, 2005 at 10:10 pm
    Thanks Pete,
    I’m away on a shoot, but will do some tests when I get back to the studio. It will get halfway througha render then crash PPro to Desktop. I’ll confirm though.
    Regards,
    Peter
