Activity Forums Adobe After Effects Free script for replacing multiple footage files
  • Free script for replacing multiple footage files
    Posted by Gabriel Valkama on October 2, 2014 at 8:12 am
    Hello!
    I made a simple script for easily changing multiple footage paths. I’m a 3D artist and found it a burden to replace all the vray render passes every time I rendered a new version. I’m sure it has other uses as well, like checking and setting which of your footage files are local and which ones are on a fileserver.
    You can also copy and move footage from one file to another with this tool.
    I’m not a professional scripter and would like some comments and crits. What would be the best place to publish something like this? For 3ds max there’s scriptspot.com, is there something similiar for adobe scripts?
    Use at your own risk. Download here.
    Kevin Snyder replied 11 years, 11 months ago 3 Members · 18 Replies
  • 18 Replies
  • Roland R. kahlenberg
    October 4, 2014 at 12:14 am
    Try aescripts.com and https://aenhancers.com/
    Cheers
    – Roland
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
  • Kevin Snyder
    October 4, 2014 at 11:25 pm
    Awesome. Looking forward to giving it a go.
  • Kevin Snyder
    October 5, 2014 at 12:36 am
    Does it only work with image sequences?
  • Gabriel Valkama
    October 6, 2014 at 11:11 am
    It should work with all footage items. Sequences, stills, audio, etc.
  • Gabriel Valkama
    October 6, 2014 at 11:12 am
    Thank you for the suggestions!
    I guess I did some very lazy googling on the subject. I’ll check those out.
  • Kevin Snyder
    October 6, 2014 at 2:46 pm
    I’ll have to give it a go again. I couldn’t get it to work with video files.
  • Gabriel Valkama
    October 6, 2014 at 5:40 pm
    Good point, I didn’t test this with video clips at all. I should have time to look at that tomorrow.
  • Gabriel Valkama
    October 7, 2014 at 6:59 am
    I just gave it a go and it worked fine with .mp4 and .wmv files.
    How did you test this?
    If you used the ‘Paste path’ button, the footage must already exist in the new location. Otherwise you have to use the ‘Move footage’ or ‘Copy footage’ buttons. With those buttons the folder must already exist.
    EDIT:
    Took some time to bump into the problem myself, I fixed it and the new version (v07) can be found at the same place. Thank you for your feedback!
  • Kevin Snyder
    October 7, 2014 at 3:02 pm
    Great. I’m looking forward to giving it a try. I’ll give it a go later today and let you know what I discover. Thanks.
    Kevin
  • Kevin Snyder
    October 8, 2014 at 2:39 am
    Just tested the new version. Everything is working as expected. Thanks for the great tool. Should come in handy.
    Any chance of the ability to replace image sequences with video files? Sometimes I convert my images sequences to video files in Adobe Media Encoder in order to consolidate a project. It can be time consuming to relink the images sequences to video files. I’m not sure if it’s possible… Thanks again.
