Activity › Forums › Apple Final Cut Pro Legacy › Freaky Sequence issue
  • Daniel Schultz
    June 13, 2013 at 10:03 pm
    When I did an XML export, then imported the XML into a new project, the timeline that came up had all the clips offline. The original timeline is all connected fine.
    Dan S.
  • Daniel Schultz
    June 13, 2013 at 10:17 pm
    But at least the clip names are correct.
    But then when I try to reconnect the media, I get wonky error messages, but I click “ok” anyhow.
    Sometimes it reconnects properly, and other times it comes in out of sync.
    Should I just rebuild the @#$@ timeline to be safe?
    Proabably 2 hours work. Deadline: Project due tomorrow morning.Yow!
    Dan S.
  • Shane Ross
    June 13, 2013 at 10:18 pm
    What aspects of this project are due? The final video? Or is an EDL or XML needed too?
    Shane
    Little Frog Post
  • Daniel Schultz
    FInal video
    Dan S.
  • Shane Ross
    June 13, 2013 at 10:22 pm
    Then there is nothing to worry about. Export the video…you are fine.
    Shane
    Little Frog Post
  • Daniel Schultz
    June 13, 2013 at 10:30 pm
    Except the old sequence (with the wrong names) was incorrect and wonky.
    And the new XML export/import sequence has offline media, and doen’t seem to want to reconnect properly.
    Make sense?
    Dan S.
  • Shane Ross
    June 13, 2013 at 10:31 pm
    [Daniel Schultz] “Except the old sequence (with the wrong names) was incorrect and wonky.”
    In what way?
    [Daniel Schultz] ”
    And the new XML export/import sequence has offline media, and doen’t seem to want to reconnect properly.”
    Why are you doing this?
    [Daniel Schultz] “Make sense?”
    WHy it doesn’t work? yes. Why you are doing it…no.
    Shane
    Little Frog Post
  • Daniel Schultz
    June 13, 2013 at 10:36 pm
    I am 95% finished with this job that needs to be done tomorrow.
    THat’s when the sequence naming bug happened.
    So I just want to get back to where I was a few hours ago before this bug happened so I can finish the job and deliver it.
    The question is:
    1. Do I try to make it work with the XML timeline that seems to be problematic?
    2. Or just rebuild the timline to where I was earlier in the day, then finish off the job.
    Yes???
    Dan S.
  • Shane Ross
    June 13, 2013 at 10:38 pm
    [Daniel Schultz] “2. Or just rebuild the timline to where I was earlier in the day, then finish off the job.”
    This.
    Shane
    Little Frog Post
  • Daniel Schultz
    June 13, 2013 at 10:43 pm
    Okay…I might have solved it.
    I went to the autosave vault and got a recent version, opened the timeline (that was named wrong, but the clips are named correctly), then copy and pasted clips into a new timeline with correct settings.
    So far so good!!
    Thanks for your patience, Shane!
    Dan S.
Page 2 of 2
