Activity Forums VEGAS Pro FRAPS AVI Black Screen
  • FRAPS AVI Black Screen
    Posted by Ryan O’brian on February 7, 2013 at 4:16 am
    Hello there, I use Sony Vegas Pro 12.
    Someone I know, and I have been having issues with FRAPS AVIs. They have been randomly blacking out in the video for no reason, and it seems like they just choose to go black.
    The Preview goes black, as well as the rendered version. I can fix this by removing the clip and re-adding it, but I’d like to permanently fix this if possible.
    If it helps, here is the information of one of the blacked out clips.
    General
    Complete name : D:\Tour\mafia2 2013-02-06 22-03-39-18.avi
    Format : AVI
    Format/Info : Audio Video Interleave
    File size : 3.95 GiB
    Duration : 3mn 28s
    Overall bit rate : 163 Mbps
    Video
    Format : Fraps
    Codec ID : FPS1
    Duration : 3mn 28s
    Bit rate : 157 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate : 60.000 fps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 2.832
    Stream size : 3.80 GiB (96%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Duration : 3mn 28s
    Bit rate mode : Constant
    Bit rate : 6 144 Kbps
    Channel(s) : 2 channels
    Sampling rate : 192 KHz
    Bit depth : 16 bits
    Stream size : 153 MiB (4%)
    Interleave, duration : 998 ms (59.87 video frames)
    I will post the black screen on Vegas soon, thanks.
    Ryan O’brian replied 13 years, 6 months ago 2 Members · 2 Replies
  • Odd Mathisen
    February 7, 2013 at 10:30 am
    I had a similar problem when rendering earlier.
    If this is the same issue you’re having(black screen in rendered footage, even though source footage looks ok) do the following:
    Click the options drop down at the top in vegas.
    Click Preferences.
    Under the “General” tab look for “Close media files when not the active application.”
    Make sure that selection is not enabled.
    Basically what the setting does is clear media file usage as soon as you deselect the Vegas window, which most people do when rendering footage.
  • Ryan O’brian
    February 8, 2013 at 11:00 pm
    Thanks, I hope this will work.
    I appreciate the help.
