Activity Forums Apple Final Cut Pro Legacy Frames off at end of project — Help!
  • Frames off at end of project — Help!
    Posted by David Lewis on January 22, 2007 at 3:57 pm
    In preparing a DV project for broadcast, I am noticing what seems to be an extra frame at the end. The project needs to be 26:46:00, but I’m seeing that the last frame (with the green corner in the lower right corner of the frame) is at 26:45:29, and there is one frame that appears to be empty after that with a bluish-purple line striped down the right side of the frame. I have tried to trim it out and expand a clip internally in the sequence by one frame, but it just moves the end slip back one frame (do it doesn’t complete the fade-out) and I still get the extra frame with the purple stripe and no content. What is this? Is this a drop-frame, and if so, how do I solve it? Is it something I need to worry about, or will the broadcaster still be happy? please advise, I have to ship the hard drive out today. Many thanks!
    Dave
    David Lewis replied 19 years, 8 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    January 22, 2007 at 4:00 pm
    The purple stripe is only on your browser and that is FCP saying that it’s at the end of the timeline. When you watch this program out to a tv monitor (which you should be doing anyway), you won’t find that problem.
    Jeremy
  • David Lewis
    January 22, 2007 at 5:06 pm
    thanks!
