Activity Forums Adobe After Effects frames not rendering as they should!!! (as they look in the rampreview)
  • frames not rendering as they should!!! (as they look in the rampreview)
    Posted by Manojit Ghose on August 24, 2009 at 11:46 am
    hi,
    i am trying to make a small test animation with trapcode form, everything is fine… the ram preview shows exactly what i want…but when i am hitting render some frames are not rendering as they are in the cop!
    its rendering something which is non-existant in my comp! (they are form particles but not the way the are displaying in the comp.)
    my comp settings are:
    NTSC D1 Widescreen Sq Pixel preset
    872×486
    fr 29.97
    (no skip frames are enabled)
    i would appreciate any kind of efforts from you guys.
    thanks
    manojitghose@gmail.com
    MG
    Manojit Ghose replied 17 years, 1 month ago 2 Members · 2 Replies
  • Todd Kopriva
    August 24, 2009 at 3:06 pm
    Do your resoultion settings match between your Composition panel and your render settings? I’ve noticed that some particle effects behave differently at different resolution settings.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Manojit Ghose
    August 25, 2009 at 7:21 am
    hi
    thanks for answering, if you are talking about the resolution settings of the time controls. yes i have matched them (framerates,resolution and no skip frames),
    i’ve even checked the render settings properly. they are exactly what they should be… but when its rendering…in the sixth keyframe the frame is entirely different from what it shows in the comp.
    this is bizzare.
    i have a camera with DOF animated (had a keyframe in the 6th frame) i even tried to get rid of that but no luck. now i do not have any kind of keyframe in that frame the …yet it behaving the same way!!!
    manojit
    MG
