Activity › Forums › Adobe Premiere Pro › frames fitting in the program monitor
  • frames fitting in the program monitor
    Posted by Frits Hoeksttra on December 29, 2010 at 3:12 pm
    Which sequence preset in Premiere Pro do I have to choose when I use the Sony Camcorder HDR-CX115?
    The frames used with this camcorder have the extension MTS.
    When I choose the sequence preset of DV PAL, I get the best result when making a DVD with Encore. But the frames are not entirely shown (they are cut around). Who can give me advise with this problem?
    Vince Becquiot replied 15 years, 9 months ago 2 Members · 3 Replies
  • Vince Becquiot
    December 29, 2010 at 5:38 pm
    Hi Frits,
    You are dealing with HD footage.
    Your best option is to edit in HD, creating a new AVCHD sequence, then exporting as Mpeg 2 DVD, or to Encore via Dynamic Link.
    In CS5, you can also drag one of the files to the “New Sequence” icon at the bottom of the project panel, that will create a sequence matching your footage
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Frits Hoeksttra
    December 29, 2010 at 6:14 pm
    Hi Vince,
    Thank you very much for your fast reaction!! I will give it a try.
    Can you explain why the quality, when chosen for DV PAL is better on the final DVD (made with Encore), compared to when chosen for example the XDCAM EX sequence setting. In this setting you see more ‘moiree’.
    Kind regards, Frits.
  • Vince Becquiot
    December 29, 2010 at 7:19 pm
    [Frits Hoeksttra] “Can you explain why the quality, when chosen for DV PAL is better on the final DVD (made with Encore), compared to when chosen for example the XDCAM EX sequence setting. In this setting you see more ‘moiree’.”
    This is because you weren’t scaling down to fit the frame. When you create an HD sequence Encore does the scaling to fit the DVD frame.
    Make sure you choose Maximum Quality for your encoding as it will affect scaling quality. That will also make the encode quite a bit longer…
    Vince Becquiot
    Kaptis Studios
