Activity › Forums › Adobe After Effects › Frames do not match up when importing image sequence into AE
Posted by Ashley Mitchell on March 7, 2013 at 3:30 pmI create a new comp in AE of 100 frames, change the timeline to display frames instead of seconds. I drag a folder containing 100 jpeg images into AE as a sequence. I drag the sequence onto the timline and its now 84 frames long. What is happening here? Any help on this would be much appreciated. Hopefully its a quick one! (famous last words)
Ashley
John Cuevas replied 13 years, 7 months ago 2 Members · 5 Replies -
John Cuevas
March 7, 2013 at 4:23 pmWhen you are importing are importing as a sequence, because AE can skip some pics if there are problems? And are you sure that all the pictures are in a format that AE can use? For example are you sure that there aren’t any CMYK issues?
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Ashley Mitchell
March 7, 2013 at 4:55 pmThanks Johnny..
I have tried RGB jpegs and PNGs (I’m rendering from 3DsMax). I’m getting close. If I drag the folder into AE it creates a sequence and says 1280×720 (1.00) 30fps. I am working in a 25fps comp, could this be why?
If I drag the image sequence onto ‘create a new composition’ I have no problems because the new comp is 30fps.
How do import an image sequence as 25fps?
John Cuevas
March 7, 2013 at 5:28 pmYou can change the import for AE by going to your Edit > Preferences > Import and changing Seq Footage to 25FPS or if it’s easier, go to your project window, right click on the pictures sequence and choose Interpret Footage > Main(Cntl-Alt-G). Now change the frame rate to 25
Ashley Mitchell
March 7, 2013 at 6:59 pmYou are a digital legend. Thanks.
Now the Magic can begin..
John Cuevas
March 7, 2013 at 8:48 pmYou are a digital legend
I might put that on my business cards…glad I was able to help you out today.
