Activity › Forums › VEGAS Pro › Frames Being Skipped
  • John Rofrano
    March 19, 2009 at 12:03 am
    Did you specify the correct frames per second when you imported the image sequence and is your project set to the same frames per second? If not, you are seeing the frames that Vegas has to create because the fps doesn’t match between the media and the project.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
Page 2 of 2
