Activity Forums Adobe After Effects Frames and custom measurement
  • Frames and custom measurement
    Posted by John Bone on July 23, 2010 at 7:18 pm
    HI
    I have a question.
    I work alot with music videos and work from a given bpm most of the time. Say the track = 12 frames to the beat I have gotten into the habit of creating a slug / measurement ruler to ensure my layers are running properly. This sometimes is a blank layer with markers placed at every 12 frames, sometimes its a blank layer cut to 4 beats ( 48 frames ) and duplicated throughout the timeline. My question is this, my way is a very labourious way of keeping track of every 12th frame, as I have to set each marker by hand, is there any easier method for me to keep tabs of my custom measurement within AE and across the whole timeline? in and out of diferent comps ?
    thanks
    JB
    Kevin Camp replied 16 years, 1 month ago 3 Members · 4 Replies
  • John Bone
    July 23, 2010 at 8:32 pm
    I see what you mean Dave
    I guess I will have to get to grips with audio keyframes then and use these as pointers, only I would still like to be able to visually jump between 1 bar 2 bar 4 bar of frames, and looking at keyframes makes me go crosseyed!
    So does that mean there IS no other way than the manual way?
    cheers
    JB
  • Michael Szalapski
    July 23, 2010 at 9:34 pm
    If you have a layer selected you can tap the * key on your number pad during an audio preview in AE to add layer markers. If you don’t have a layer selected, it adds composition markers. If you work with Premiere, you can do the same thing to add timeline markers which – when the Premiere project is imported into AE – brings those into AE. This just requires a basic understanding of the song and one listen-through with your hand tapping out the beat.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • John Bone
    July 24, 2010 at 5:07 pm
    And Dave you have given me a great idea . .
    A simple color key.mov created in FCP relating colors to beats and bars / 1 beat / 1 bar / 4 bar / and changes in verse and chorus. something that can be placed at the top of my AE timeline scaled very small but give me an indication of key audio changes.
    This will take me a little prep but once in After Effects, will speed up my workflow no end! thanks!
  • Kevin Camp
    July 26, 2010 at 8:59 pm
    if your beats are truly as regular as every 12 frames (as your earlier example), you could try something like the strobe light effect set to ‘makes layer transparent’ on a solid that is at the top of the comp.
    the duration and period are set in seconds, but entering a simple equation of frames/framerate will convert frames to seconds. if your frame rate is 29.97, a duration of 1/29.97 and a period of 12/29.97 would give you a one frame ‘pulse’ every 12 frames.
    of course your solid could be anything… a square, a line, an x… whatever you wanted to use as a marker.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
