Activity Forums Audio framerates (not) working together
  • framerates (not) working together
    Posted by Joe Lawlor on June 4, 2005 at 7:55 am
    Hi folks,
    Sure hope you can throw light on this one.
    I’ve just completed a short which I shot on 35mm at the standard 24fps. This film had sync. sound. When I got the telecine done it was converted to 25fps for more ease of use in my studio set up. After top and tailing what I need and getting a picture lock I then exported the quicktime file so as I could import it into my Protools set up (i’m using LE 6.4).
    I then import the DAT masters which the recordist did and to be expected they do not sync up because one is at 24fps and the other at 25fps. How do I change the audio to now work at 25fps.
    I’ve tired the TCE tool in protools but it very hit and miss and actualy makes the voices sound a bit flangy.
    IS there a more scientific rock solid way – or have I gone about thsi the wrong way?
    Any thoughts wouldbe VERY appreciated.
    joe
    Joe Lawlor replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
