Activity Forums VEGAS Pro Framerate problems
  • Framerate problems
    Posted by Adrian Fox on January 30, 2012 at 9:29 am
    I am trying to render a large project from Vegas but I’m having problems with the framerate, the video was originally recorded in 60fps (59.940 in Project Properties) and I want to render to 30fps, but whenever I do the video comes out laggy and it is annoying to watch, and the only way I can solve this problem is by rendering 60fps instead which would take me 17 hours to do, so if you could save me 9 or so hours and help with this problem I’m having I’d really appreciate it.
    Rendering framerate : 29.970 (NTSC) – I have also tried 24.000 (Film) and 23.976 (IVTC Film) and they were even worse.
    John Rofrano replied 14 years, 7 months ago 2 Members · 5 Replies
  • John Rofrano
    January 31, 2012 at 9:27 pm
    [Adrian Fox] “the video was originally recorded in 60fps (59.940 in Project Properties) and I want to render to 30fps, but whenever I do the video comes out laggy and it is annoying to watch”
    Try right-clicking on each even and open the Properties and check Disable Resample. This will tell Vegas to create 30fps by dropping every other frame. It might help.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Adrian Fox
    February 1, 2012 at 1:31 pm
    Already done I’m afraid, I do this with every clip I import.
  • John Rofrano
    February 1, 2012 at 5:49 pm
    What are your render settings? What format? What template? What did you change about the template (if any)?
    ~jr
  • Adrian Fox
    February 2, 2012 at 7:54 pm
    Sony AVC format
    Custom Template :
    Video format : AVC
    Frame Size : 1280×720 (Allow source to adjust frame size left unticked)
    Profile : Main
    Entropy coding : CABAC
    Frame rate : 29.970 (NTSC)
    Field order : None (progressive scan)
    Pixel Aspect Ratio : 1.000
    Bitrate : 8,000,000
    Encode mode : Automatic (recommended)
  • John Rofrano
    February 5, 2012 at 2:57 am
    Those are pretty standard settings. Why use a custom template? Why not use the Internet 720-30p template? Anyway… what’s laggy about it? That template should produce smooth video. It’s hard to say what might be wrong.
    The only think I can say is don’t shoot 60p if you plan on delivery 30p.
    ~jr
