Activity › Forums › Adobe Premiere Pro › framerate is a lie!
  • framerate is a lie!
    Posted by Dan Babcock on January 27, 2010 at 5:10 am
    I have a previously rendered video at 29.97fps that I needed to make a 30ish second preview of. So I plopped that full quality uncompressed vid into my sequence (which has a 29.97fps setting) and did my editing and encoded again with the same settings (29.97 fps).
    Quicktime confirms that the first source video is 29.97, but this new video is 29.06fps despite all the premiere settings.
    What could have caused this and how can I get Premiere to give me a clean 29.97?
    Heres some other settings:
    original video according to quicktime:
    Format –
    Uncompressed 8-bit 4:2:2, 640 x 480, Millions
    16-bit Integer (Little Endian), Stereo (L R), 48.000 kHz
    FPS –
    29.97
    Data size (its uncompressed) –
    24.77 GB
    Data rate –
    148.89 mbits/s
    Duration –
    0:00:23:49.39
    Size
    640 x 480 pixels
    preview encoded according to quicktime:
    format –
    FPS –
    29.06
    data size –
    551.37 MB
    data rate –
    144.40 mbits/s (why is this different???)
    size –
    640 x 480 pixels
    Encode settings in Premiere –
    Quicktime format, custom preset
    codec: uncompressed YUV 8 bit 4:2:2
    quality : 100
    640×480
    frame rate – 29.97
    progressive
    square pixels(1.0)
    render at maximum depth is on
    codec settings: 24 bit
    optimize stills is checked
    Dan Babcock replied 16 years, 8 months ago 4 Members · 5 Replies
  • Scott Roberts
    January 27, 2010 at 7:23 am
    When you bring that rendered file back into Premiere, or Vegas, or FCP, what frame rate does it say the file is?
    https://www.myr3d.com
  • Dan Babcock
    January 27, 2010 at 7:30 am
    I brought the video that quicktime says is 29.06fps back into premiere and premiere thinks that its 29.97….lies
  • Jeff Burford
    January 27, 2010 at 6:32 pm
    So, my Question to you, who is lying?? Which Version of Quicktime and on what type of System? And why in heavens sake would anything create such a file with a rate of 29.06 fps?
    Could also easily be that Premiere knows that 29.06 fps a bogus Frame Rate for the specific file is and bumps it to what it believes it should be.
    Also, can you upload teh file or a portion of it somewhere for us to download and intrepret?
    cheers
  • Jeff Brown
    January 28, 2010 at 2:07 pm
    For a third opinion: download “GSpot” (freeware), a handy “what kind of video file is this” utility, and see what it says about frame rate.
    -jeff
  • Dan Babcock
    January 28, 2010 at 6:50 pm
    My boss is the one who actually noticed the weird framerate using some outside encoding software, and quicktime gave me the same numbers(concatenated to 2 decimals) it was giving her, but another program could be useful especially if it gives more detailed information. I will definitely try Gspot when I get home tonight. I tried rendering out a smaller clip to post, but I ran into some very weird behavior.
    All of the small clips that I rendered out were confirmed to be 29.97fps by quicktime. I rendered out several at different lengths and only noticed bad framerates for videos above 30 minutes. Exactly 30 minutes was 29.97, but as I went up from there the fps dropped slightly. I’m willing to upload one of the videos, but they are half a gig for 30 minutes where the errors start occuring.
