Activity Forums Adobe After Effects Framerate Error Message When Rendering
  • Framerate Error Message When Rendering
    Posted by Dmitry Sokolov on April 27, 2011 at 12:57 am
    Hi i’m disparately in need of help with the message i receive when trying to render my composition. i’m trying to output in .mp4 format (using h262 codec for lowest file size) and get the below error, preventing from rendering. I have no idea what/where to adjust the frame rate… I know there is a frame rate option in the ‘composition’ tab.. but no matter how high/lod (within reason) i set it, no luck…. (I’m using the HD TV 1080 preset in the composition menu)
    What am i doing wrong? Appreciate any help the community can offer.
    PS: the goal is to reduce the file size of the output file w/ out sacrificing quality. The file is to be used for digital signage.
    Brian Charles replied 15 years, 5 months ago 2 Members · 4 Replies
  • Brian Charles
    April 27, 2011 at 1:36 am
    Don’t transcode when you render from After Effects. Render uncompressed and transcode in Media Encoder or Compressor.
  • Dmitry Sokolov
    April 27, 2011 at 3:41 am
    Sorry guys, can you please be more specific… I’m not sure i understand.
    Should i be exporting or rendering as a. mov?
    Also, it used to work in the past, and no longer… any way someone can pin down the setting i should be looking for? Unfortunately i don’t have Sorenson or other converters…. (university student budget)…so must do it through AE…
    Any help is appreciated.
    Thank you
  • Brian Charles
    April 27, 2011 at 6:44 am
    Mr. LaRonde, thanks for your concern. All I can say is I’m working on it and there’s not an obvious, or for that matter a documented, solution.
    I’m now working on a bit of social engineering, and have offered to supply a working Mac with an HDMI cable to the AV company. The awards show is this coming Saturday and I’ve spent far too much time troubleshooting their system…
  • Brian Charles
    April 27, 2011 at 6:46 am
    Just to be clear, NEVER export from After Effects, use the Render Queue and render. Use Best Settings and Lossless compression,
