Activity Forums Apple Final Cut Pro Legacy Framerate discrepancy with imported .wav audio
  • Framerate discrepancy with imported .wav audio
    Posted by Jordan Montminy on January 13, 2010 at 11:13 pm
    What I’m trying to do is clone a FCP project from one laptop (MBP Intel OS 10.5) onto another (MBP Intel OS 10.6). The OS 10.5 laptop (Laptop #1) is connected via FW800 to a G-RAID and the OS 10.6 laptop (Laptop #2) is connected via FW 800 to a CalDigit RAID 0 drive. Both are running FCP 6.0.6.
    Both laptops have these FCP settings: Easy Setup- HDV 1080i60. Sequence Settings are also HDV 1080i60 29.97fps.
    Right now we’re only dealing w/ audio: .wav files which were converted from MP3 files via iTunes and are at 44.1khz. Project is 48khz.
    The project is moving from Laptop #1 > Laptop #2.
    When Laptop #2 attempts to reconnect the .wav files, it gets a File Attribute Mismatch message: “Some attributes of one or more of the files you have chosen do not match the attributes of the original…” – Media Start/End, Rate. Throughout this, the .wav media remains unaltered from drive to drive.
    No matter whether I choose to continue or even if I change the project or sequence settings to another framerate, the clips don’t reconnect properly and in the timeline the clips are slipped– extended at the head and clipped off at the tail. It also alters the clip TC within the timeline from the original sequence.
    Here’s the kicker: In Laptop #1, the .wav clip framerate is at 30 and in Laptop #2 the .wav framerate is at 25… and it can’t be modified thru Modify>Timecode. I believe this is why the clips aren’t synching up correctly with the timeline? Both timelines are at 29.97.
    And to complicate matters, eventually both projects need to be in XDCAM EX 1080i50, 25fps for a PAL presentation. Just in case you thought this was going to be too easy…
    Any help would be greatly appreciated…hopefully it’s just a hidden tweaky FCP setting somewhere…
    Thanks.
    Chris Bauman replied 15 years, 1 month ago 2 Members · 1 Reply
  • Chris Bauman
    July 22, 2011 at 2:40 am
    This is an old thread, but apparently Apple hasn’t addressed the issue. While researching a similar problem, I found a fix thanks to a discussion on Apple’s site:
    The best way I’ve found to share a project is to make sure the file directory structure and drive name match exactly on both systems. That way there are no reconnect issues at all. Cloning the drive is the easiest way to do it and then simply rename the drive to match the original drive. I usually add an x to the end of the drive name so that there are no problems caused by having to identical drives on the same system. And then I remove the x from the drive name when I connect the drive to the other system (but before I launch fcp).
    This instantly fixed the problem for me. I didn’t even clone the drive – I just changed the drive’s name. Not sure why FCP thinks the rate has changed when all I did was copy the file…!
